Q. When using Natural Size in ICEM CFD Tetra, is it possible to override the mesh parameters on specified curves and/or surfaces?
Tagged: 17.2, fluid-dynamics, General, icem-cfd, Tetra/Prism
March 17, 2023 at 8:58 am
FAQParticipantQ. When using Natural Size in ICEM CFD Tetra, is it possible to override the mesh parameters on specified curves and/or surfaces? A. Yes, you can do this by setting specific mesh parameters on individual curves or surfaces under the tab, Mesh ==> Surface Mesh setup or Curve Mesh setup
- Skewness in ANSYS Meshing
