Q: The geometry has been changed and now I’m getting the following error in CFX-Pre: “The supplied name, “[Name of region]” is not a composite name.” How to resolve this issue?
Tagged: 19.2, cfx, fluid-dynamics, General, General - CFX
March 17, 2023 at 8:58 am
FAQ
ParticipantA: This error in CFX-Pre happens on occasion when geometry is changed, the setup is changed accordingly, but something is left behind from the previous setup to cause this error. The steps outlined below may help with this: 1) In CFX-Pre, select File>Export>CCL 2) Important: In the top-right of the box that opens up, click “Save All Objects” 3) Write the file to somewhere convenient like the user_files folder 4) In Workbench, right-click “Setup” and hit “Reset” 5) Double-click setup to import the mesh into a now empty session 6) Select File>Import>CCL, and browse to the file you wrote earlier 7) All the physics is now put back to how it was before.
- Skewness in ANSYS Meshing
