Tagged: 2019 R1, fluent, fluent-post-processing, fluid-dynamics, post-processing
March 17, 2023 at 8:58 am
FAQParticipantA: No it is not possible. The dat file contains only the last time step information. In order to create a video you have to specify the animation setup before running your simulation or you have to save all the data file for each time step.
- Skewness in ANSYS Meshing
