Q: How to solve resolve this error message in license Management Center: “Invalid Option for this License server”
April 5, 2023 at 2:32 pm
FAQ
ParticipantA: You must modify “Advanced Options” > “Specify License Manager Run Mode” and select “Run the ANSYS Licensing Interconnect with FlexNet”.
