Tagged: fluid-dynamics, General, workbench, workbench platform
April 5, 2023 at 2:31 pm
FAQParticipantIn the parameter set, edit expression defining a parameter. Here you can make it a function of other parameters, such as setting it to max(P1,P2). There are may functions available, such as floor(arg), ceil(arg), sin(arg), and more as detailed in the documentation. Keywords: Parameter function of other parameter, WorkBench
- Skewness in ANSYS Meshing
