March 17, 2023 at 1:12 pm
Solution
ParticipantA: See example attached: example_NL_torsinal_spring_R161.wbpz Summary: -Use two remote nodes as pilot nodes -Use combin39 element between the pilot nodes -Define dof and force-deflection curve on combin39 real constants -Solve activating Large Deflections
1. 2042441.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
