June 5, 2023 at 7:04 am
FAQParticipantA: whatever we use DM or Spaceclaim, it’s not possible yet to define tapered cross sections along the beam length. We need to keep a uniform cross section and use a command insert below the corresponding body in mechanical with the following commands (for instance): sectype,100,beam,rect ! define cross section at first end point secdata,1,1 sectype,101,beam,rect ! define cross section at far end secdata,5,5 sectype,matid,taper ! new Section ID for tapered beam analysis secdata,100,0.0,20,0 ! section 100 at location (0,20,0) secdata,101,0,40.0 ! section 101 at location (0,40,0)
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
