January 25, 2023 at 7:28 am
FAQ
ParticipantTo create the required file, first go to : Start Menu > All Programs > Ansys [version number] > Ansys Client Licensing > Client ANSLIC_ADMIN Utility > ‘Specify the license Server Machine’ and then specify the hostname for the licence server. Important : The Client ANSLIC_ADMIN Utility should be run as administrator or the procedure might not work properly (open the utility with a right mouse button click / run as administrator).
