Q: How do I converge the solution when simulating a porous region with the real velocity formulation in Fluent
Tagged: 19.1, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantA: The real velocity formulation has difficulty converging when the resistance of the porous region is relatively low. A workaround is to convert the interior interface between the porous zone and non porous zone to a dummy porous jump boundary condition with default values.
- Skewness in ANSYS Meshing
