Q: Fluent runs OK with local parallel but distributed parallel with Intel MPI on WIndows hangs. The last line on the console contains Host spawning Node 0 on machine
Tagged: 2019 R1, fluent, fluid-dynamics, General - FLUENT, installation, parallel
January 25, 2023 at 7:16 am
FAQParticipantA: The default Intel MPI library that gets installed at Ansys verison 2019R1 is version 2017.3.210. This has problems initiating a distributed parallel run. There is a newer version in the Ansys installation folders at “C:Program FilesANSYS Incv193commonfilesMPIIntel2018.3.210Windows”. Installing this version on all machines involved in the distributed run should fix the problem.
- Skewness in ANSYS Meshing
