Q: After configuring Inventor CAD interface, it showed configured successfully, but Workbench still does not show up in Inventor. What can be done to fix this issue?
January 25, 2023 at 7:28 am
FAQParticipantA: If you have configured successfully with the CAD Configuration Manager, you probably have to go to Inventor and look in Tools >> Add-Ins. Then unblock it, and set it up to load on startup. It’s a security feature in Inventor.
