Tagged: 18, cfx, CFX path, cfx5solve, fluid-dynamics, General - CFX, PATH environment variable
June 5, 2023 at 7:05 am
FAQ
ParticipantIn order to run the CFX solver, Pre or Post from a command prompt (ie.running cmd.exe on Windows to generate a command prompt), the path to the CFX bin directory needs to be included in the PATH environment variable which is accessed from Start->Computer->Properties->Advanced System Settings->Environment Variables. Under System Variables, edit the “Path” environment variable. After adding a semicolon to the end, enter the path to the CFX bin directory (i.e. C:Program FilesANSYS Incv180CFXbin).
- Skewness in ANSYS Meshing
