Problem: I have a combustion solution where my species monitors are exhibiting wide, saw tooth swings, but there is no corresponding fluctuation in global temperature. My reactions are implemented with UDF source terms. The time step is small and residuals generally look quite good. What might be causing this?
Tagged: 17.2, Convergence Problems, fluent, fluid-dynamics, General, Species/Reactions
January 25, 2023 at 7:17 am
FAQ
ParticipantIn this case, it is likely that the monitor locations are the culprit. If monitors are located are near a wall, and there is no near-wall resolution, for instance, the monitors will exhibit fluctuation as follows: UDF implemented reaction rates may be zero at the wall, so monitored values of species concentrations just off the wall will wander between reacted and unreacted extrema. The solution is to refine the near-wall mesh and locate the monitors further into the boundary layer
- How do I model humidity in Fluent?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- Model setup: Setting up chemical reactions
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How do I use the Flamelet Generated Model?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- How can volume fraction be plotted in a species transport simulation?
- LES Simulation of Turbulent Flames Using ANSYS Fluent
