Tagged: 2019 R3, fluent, Fluent-CFDPost IO, fluid-dynamics, NA
April 13, 2023 at 7:33 am
SolutionParticipantTill 2019R3 version , For multiphase VOF case -default .dat file does not contains the pressure variable data available for post processing in CFD post . We need to go to fluent –> File –> Data file quantities and add All pressure related variable from additional quantities and run one more iteration to get this data under standard .dat file . Please refer image attached for your reference .
- Skewness in ANSYS Meshing
