June 6, 2022 at 9:30 am
Watch & LearnParticipantIn the video, you will learn post processing for composites and calculating torsional stiffness of a frame using ANSYS Mechanical. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
