POLYFLOW – Solver ends with the message “Blocs exhausted. NBLOCS > 20000 in the .p3rc file.”
- 20000 in the .p3rc file.”" target="_blank" rel="nofollow" title="LinkedIn">
- 20000 in the .p3rc file.”" target="_blank" rel="nofollow" title="whatsapp">
- 20000 in the .p3rc file.”" target="_blank" rel="nofollow" title="reddit">
- 20000 in the .p3rc file.”" target="_blank" rel="nofollow" title="facebook">
March 17, 2023 at 8:58 am
FAQ
ParticipantA POLYFLOW case is defined where the output for CFX-Post is asked. The calculation stops with the error message “Blocs exhausted. NBLOCS > 20000 in the .p3rc file.” . What can be done? Some internal table is growing beyond the allowed limit. It is suggested to increase the parameter, as indicated and to rerun the calculation with the .p3rc file. If necessary, the calculation can be restarted. The value for NBLOCS should be selected on the basis of the expected number of steps. This has been fixed in later Releases (from R17.0 – … ).
- Skewness in ANSYS Meshing
