POLYFLOW : Shear rate (post-)calculation in parallel coextrusion film casting: error message in getfld (Incoherent problem table)
March 17, 2023 at 8:58 am
FAQParticipantCoextrusion film casting flow case: the calculation crashes in the post-calculation of the shear rate, and the following message is issued after attempting the first iteration: ******************************** * Summary of the simulation * ******************************** The computation failed. *************************** * Expert tool diagnostics * ************************** ERROR in SOLVER section 55 in getfld Incoherent problem table ! The trouble originates from the definition of several THICKNESS fields, in view of the coextrusion case. This has been fixed in the release 3.10.2. With version 3.10.0, the easiest remedy consists of running POLYDATA with the keyword NO_AUTO_POSTPRO in a p3rc file.
- Skewness in ANSYS Meshing
