POLYFLOW: Initial boundary conditions at the inlet (orientation, anisotropy, stretching) for the DCPP model in film casting
Tagged: 16, Film Casting, fluid-dynamics, General, polyflow
March 17, 2023 at 8:58 am
FAQParticipantWhat is the definition of the stretching variable (in words)? What typical values can be imposed? At a microscopic level, the stretching variable is the ratio of the current length of the molecule to the initial one. In shear flow, stretching is often very moderate. Now, the word “moderate” has to be understood objectively: the number can be small but it may have already a significant meaning in the physics! What is the typical value that can be imposed for anisotropy factor? One should keep in mind that right before the die exit in film casting, the material has mainly undergone a shear flow. Under normal shear conditions, the resulting anisotropy is moderate, so that s = 0.1 is already a good choice.
- Skewness in ANSYS Meshing
