March 17, 2023 at 8:58 am
FAQParticipantHow to direct the buffering files in a given directory? By default, the buffer files will be written in the directory where the simulation has been launched. Assigning a given directory for the buffering can be done as follows: – Open a shell on the calculation computer – Enter the command % setenv TMPDIR
– Run the simulation (possibly through POLYMAN)
- Skewness in ANSYS Meshing
