Tagged: adaptive-meshing, fluid-dynamics, General, Other, polyflow
March 17, 2023 at 8:58 am
FAQParticipantA mesh contains triangles which are nearly equilateral. The simulation involves adaptive meshing, with Tquality = 0.25 and the element size = 0.05 or 0.02, e.g. A simulation is defined such that the mesh does nearly not deform. If the value 0.05 is selected for the element size, the domain is not remeshed. If the value 0.02 is selected for the element size, the domain is remeshed at the fourth step, although the element quality is fine (nearly equilateral triangles). Elements are picked for remeshing if at least one of both following conditions is verified: – the quality is below the assigned value, – the size is not within the interval [S/2,S*2]. However, it is probably reasonable that the user select a size S, which is compatible with the mesh as initially provided. If the user specifies a smaller size S, it is then understood that the user indeed wants this size. Currently, the value 0.02 is significantly smaller that the initial element size.
- Skewness in ANSYS Meshing
