POLYDATA: Error messages at the end of the session: “Error during opening of a temporary file.”, “Sub-tree copy has failed!”
March 17, 2023 at 8:58 am
FAQParticipantAt the end of a POLYDATA session, the following error messages are generated: ***WARNING*** from *COPTRE* Error during opening of a temporary file. ***FATAL ERROR*** from *CRVOLU* Sub-tree copy has failed ! Subsequently, the POLYDATA session is aborted and the data file is not properly generated. One of the following causes may possibly explain the trouble: – Pathname too long (the most probable cause) – Disk full (or nearly full) – Unsufficient access rights
- Skewness in ANSYS Meshing
