Tagged: ansys-student, Plate Heat Exchanger, spaceclaim, workbench
June 6, 2022 at 10:54 am
Watch & LearnParticipantIn this video, you will learn how to model a simplified plate heat exchanger in ANSYS Spaceclaim. The geometry will be created using a linear pattern of an initial plate. Named selections will be applied to all geometry faces and the final bodies will be exported to Fluent Meshing. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
