PExprt and PEmag error: ERROR: ‘pexprt’ License checkout failure Unable to connect to or start local server
Tagged: 2020 R2, ansyscl, Installation/Licensing/Systems, licensing, Other, PExprt - SYS
January 25, 2023 at 7:28 am
FAQParticipantThe following may resolve the issue you are encountering. 1) Check if you have ‘ansyscl.exe’ file located in C:Program FilesAnsysEMShared FilesLicensingwinx64 2) If you do not have ansyscl.exe file located at the above location, copy ansyscl.exe file from C:Program FilesAnsysEMAnsysEM20.2Win64licensingclientwinx64 to C:Program FilesAnsysEMShared FilesLicensingwinx64.
