Penalty Based Contact produces poor results when used to bond Shell faces together in a modal analysis. Is there a workaround
January 25, 2023 at 7:34 am
FAQParticipantTwo potential workarounds: 1. Switch to MPC or… 2. Use SECOFFSET to move the shell nodes to top and bot surfaces respectfully and turn off contact shell thickness effect.
