Patching a temperature in a shell conduction zone initially leads to unreasonable temperature values on the shell surfaces, when continuing the Fluent run in transient mode
January 25, 2023 at 7:16 am
FAQParticipantMake sure that you set the solver mode to transient before you patch the shell conduction zone. Let’s suppose you did a steady run to provide good initial data for a successive transient run. And lets further suppose you want to patch a shell conduction zone with a certain temperature on this steady solution. Then your next step should be to set the solver to transient mode before you do the patching.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
