Partially premixed combustion model may predict wrong temperatures for a premixed combustion simulation if fuel composition is not set correctly
Tagged: 16, combustion, fluent, fluid-dynamics, Modeling/Setup Advice, Reactions, species, Species/Reactions
March 17, 2023 at 6:12 am
FAQParticipantIf you use the partially premixed combustion model for a premixed combustion calculation (due to the greater accuracy obtained from the partially premixed combustion model), the temperature prediction might not be correct if you are modeling the partially premixed system by setting the fuel composition as the premixed mixture and the parameter f=1 in the whole domain. Instead of the above, set the fuel composition as pure fuel, and then set the mixture fraction in the domain correctly (i.e. equal to the mass fraction of the fuel in the pre-mixture).
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
