May 5, 2024 at 7:34 am
SolutionParticipantIn this article we will explore parametric analysis capabilities of Discovery where we will see how changing the flow speed influences lowering the temperature of CPUs for intense computations.
Refer the attached document and Simulation files which demonstrates the need of Conjugate heat transfer analysis to correctly capture the uneven temperature gradient and use parametric capabilities to automatically test several simulation variations back-to-back.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- Structural Simulation using Bolt Idealization
- How to apply bolt Pretension in ANSYS Discovery?
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
