Parametric analysis in ANSYS Workbench stops with the following error: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
Tagged: 19, fluid-dynamics, General, workbench, workbench platform
April 5, 2023 at 2:31 pm
FAQParticipantIn Windows Explorer, go to %appdata% and rename or remove the folder .ansys. Then under directory %temp% rename or remove the folder Ansys. Restart Workbench and the error should be fixed.
- Skewness in ANSYS Meshing
