Oriented Selection Sets and Modeling Groups for FSAE Composite & Monocoque Chassis in ANSYS – Part 4
June 6, 2022 at 9:30 am
Watch & Learn
ParticipantIn this video, you will learn to add orientation element sets and layers of carbon fiber onto the chassis surface as modeling groups using ANSYS Mechanical. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
