Opening a file in v10 that was created in v10 SP1 produces “the file was saved in a future version”, as expected. Then another message “do you want to save the changes?” Y/N/Cancel.
March 17, 2023 at 9:01 am
FAQParticipantPicking any option takes you back to the first message. The only way out of this loop is killing Workbench from Task Manager. This is a known defect that is fixed in v11.0.
