On adding a block on a solid mesh which is imported from other application, how can one generate conformal mesh between solid block and the imported solid mesh ?
June 5, 2023 at 7:04 am
FAQParticipantFollow the steps below to achieve the requirement: 1. Create the volume with a gap of about 1 average element edge length above the node/elem face. 2. Do an esurf on the top of the node/elem face and also on the bottom face of the volume. 3.Manually create triangular face elements connecting the edge of the node/elem region to the edge of the bottom face of the volume. This needs to make volume that is completely enclosed by the face elements. 4. Use fvmesh on that set of fave elements to generate tet volume elements that connect the two “faces”
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
