NVIDIA Quadro RTX 6000 and NVIDIA Quadro RTX 8000 should be supported and recommended GPU accelerators for ANSYS Mechanical APDL, but still gets below error in output file and solving crashes: *** FATAL *** CP = 0.297 TIME= 14:02:29 No recommended GPU devices have been detected on machine chqt5810tlab5.ansys.com. Only Tesla-series or Quadro P5000/P6000/GP100/GV100/RTX6000/RTX8000 GPU devices are recommended at this release. For optimal performance, install a recommended GPU device in this machine. If you wish to use an alternative GPU device, please review the recommendations in the section titled “Requirements for the GPU Accelerator in Mechanical APDL” in the Installation Guide for your platform.
March 17, 2023 at 9:00 am
FAQParticipantIt’s a known issue in 2020 R2 and prior releases, the workaround is to set environment variable ANSGPU_OVERRIDE=1. 2021 R1 and newer releases will fix this issue.
