August 25, 2023 at 12:15 pmFAQParticipant
When loading some CFX or Fluent results files, some variables will not be displayed and the following error message will occur: This is an issue with Intel MPI that occurs randomly. It has been fixed in 18.2. WARNING Could not find variable “Velocity” for colouring on Inlet. Command line error message: IO: io_gunzip: Data error IO: io_gunzip: decompressed too little data: got 0 bytes, expected 240000 IO: read_compressed_dataarray: decompression failed IO: read_data_block: read_data failed IO: ii_read_located_dataset_static: read_located_dataset failed The workarounds are: – use a different parallelization method – use the attached ccl (CFX cases).
1. 2051370.zip
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
