June 6, 2022 at 9:58 am
FAQParticipantThis is post processing commands should be added under the ‘Solution’ object:
resume
strs_limit=100 !element with equivalent stress larger than this limit will be outputed
my_volu_all = 0
my_volu = 0/post1
set,last
allsel
*get,my_n_el,elem,,count !count of elements
etable,vonMises,s,EQV
etable,el_volu,volu
*cfopen,el_out,dat !open a dat file to write output
*do,i,1,my_n_el,1 !do loop over all elements
*dim,avg_vonMise,array,1,1
*vget,avg_vonMise(1,1),elem,i,etab,vonMises !get vonMise stress of element i
*get,i_volu,elem,i,volu !get element volume
my_volu_all = my_volu_all+i_volu !add element volume to total volume of the model
*if,avg_vonMise(1,1),gt,strs_limit,then my_volu = my_volu + i_volu !add element volume to volume with stress over stress limit
my_volu_ratio = my_volu/my_volu_all
*endif
*ENDDO
*cfclose
