My pre-stressed structural analysis is a linear analysis (no nonlinear material/contact/large deflection). Why is the downstream eigenvalue buckling nonlinear?
Tagged: 19.2, buckling, General, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantIt is probably because you are not using MPC formulation for contact. Linear buckling only supports MPC for contact settings.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
