My FORTE run keeps failing with a negative volume error. The case ran before for only slightly different boundary conditions and I have not changed any of the solver settings.
Tagged: 19, fluid-dynamics, Forte, Forte General, Other
June 5, 2023 at 7:06 am
FAQParticipantIf there was a change in one of the motion profiles, check that the units were interpreted correctly. Profile conversion errors are a common cause of inverted mesh.
- Skewness in ANSYS Meshing
