Tagged: 19.2, cfx, fluid-dynamics, General, Heat Transfer and Radiation, Monte Carlo
March 17, 2023 at 8:59 am
FAQParticipantThis error does occur when radiation history tracking fails i.e. in the non-overlapping part of GGI interface. Previous versions before 18.0 only accidentally worked and those tracks were actually being lost. A sanity check was added in 18.0, which results in this error message when a track hits a non-overlap face. Fixed in 19.3. Full error message: +——————————————————————–+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine WALK | | | | | | | | | | | +——————————————————————–+
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
