October 19, 2022 at 7:55 am
FAQParticipantDate: August 15, 2019
Product: Ansys ModelCenter 13.2 and newer
Severity: Informational
Introduction: A Java Runtime Environment is required to install ModelCenter. A supported 64-bit
JDK or JRE should be installed before installing ModelCenter. 64-bit Java 8 LTS and Java 11 LTS are
supported.Issue: Previously, Java was distributed with ModelCenter. Oracle changed licensing for Java starting
April 16, 2019. As a result, Java will no longer be distributed with ModelCenter beginning with
ModelCenter 13.2.Impact: When ModelCenter 13.2 or newer is installed, users will need to point the installer to a
supported 64-bit JDK or JRE. Users may need to download and install Java if there is not already a
supported version installed on the system.Resolution: ModelCenter 13.2 supports 64-bit Java 8 LTS and Java 11 LTS. During install, the user
will be prompted to select a directory where supported JDK or JRE is installed. If one is not present, a
supported version of Java should be installed. An Environment Variable PHX_JAVA_HOME will be
created storing the location of the JDK or JRE.Related Information: The Oracle Java Licensing FAQ can be found at
https://www.oracle.com/technetwork/java/javase/overview/oracle-jdk-faqs.html.For more information contact Support at PHX-Support@ansys.com or 800-500-1936 Option 2
- ModelCenter Tech Note Java JDK or JRE Required to Install ModelCenter 13.2 and newer
- ModelCenter Tech Note Support for MagicDraw & Cameo 2021x Refresh 1 & 2
- ModelCenter Tech Note New Unified Component Framework
- ModelCenter Tech Note Python 2 No Longer Supported
- ModelCenter Tech Note Unexpected results when linking a double array to an integer array
- ModelCenter Tech Note Possible Data Collisions with CATIA or SolidWorks
