Message while exporting to Fluent You may either select a superdomain or a set of structured domains.
Tagged: 19.2, fluid-dynamics, General, icem-cfd, Solver output
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: fluent, v4, v6, superdomain, export, msh
1. 2057839.pdf
- Skewness in ANSYS Meshing
