Meshing issues an error/warning message: One or more objects may have lost some scoping attachments during the geometry update. What does this warning mean and how can I address it?
March 17, 2023 at 1:10 pm
Solution
ParticipantUsually, it means that some mesh controls – like the controls that set the surfaces for inflation – may not be applying to the same surfaces as before. It is a note that the associations for mesh controls should be reviewed. (Usually, some surfaces get dropped because their internal nomenclature has changed.)
1. 2058493.pdf
- Skewness in ANSYS Meshing
