Meshing brings some volumes as fluid and some as solid from SCDM. I need all fluids. What is solution?
August 25, 2023 at 12:15 pm
Solution
ParticipantPlease see attached document for solution. Keywords: material property, body name, named selection, group
1. 2050667.pdf
- Skewness in ANSYS Meshing
