Mesh translation fails with error as “”The mesh translation to Fluent failed due to conflicting zone names”. There are no overlapping named selections in the geometry.
June 5, 2023 at 7:06 am
FAQParticipantThis may happen with contacts are defined automatically and suppressed. Please change the tolerance for contacts so that no contacts are defined. Then mesh export will work.
- Skewness in ANSYS Meshing
