June 5, 2023 at 7:05 am
FAQParticipantDepending on the calculation, you may want to set a boundary (ie. wall, interior) without thickness and proceed to use CutCell to generate the mesh. Keep in mind that if you wish to apply an interior boundary, use boundary > manage and change the setting interior -> wall with TGrid /Fluent Meshing or Fluent.
- Skewness in ANSYS Meshing
