Menu items for ANSYS Workbench aren’t created correctly in the Pro/E menu and appear as follows: PI_MENU_START_APP PI_MENU_START_APP2 PI_MENU_APP_HELP PI_MENU_ABOUT_PLUGIN Workbench starts when selecting PI_MENU_START_APP, but how can I get the correct names to appear in the menu?
March 17, 2023 at 9:01 am
FAQ
ParticipantRegistering the plugin should allow the names to appear correctly in the Pro/E menu. From the Windows command prompt, change directory to “C:Program FilesAnsys Incv100AISOLCAD IntegrationProEintel†and type the following command: regsvr32 Pro2001PlugInU.dll A new window should open saying that the plug-in was successfully registered. Reopen Pro/E and the names should appear correctly in the menu.
- Q: How do I set the license server from my client machine?
