Mechanical job running on Linux cluster or machine through RSM runs into this error: OMP: Error #100: Fatal system error detected. 6565/23/2022 1:38:29 PMOMP: System error #22: Invalid argument 6575/23/2022 1:38:29 PMforrtl: error (76): Abort trap signal
Tagged: 2022 R1, cluster, Installation/Licensing/Systems, linux, Mechanical - SYS, OMP, Remote Solve, rsm
March 17, 2023 at 9:00 am
FAQParticipantSet KMP_AFFINITY=disabled on the Linux machine/cluster headnode under the user profile $HOME/.bashrc file and then submit the job again.
