Tagged: acp, acp-pre, ansys-mechanical, chassis, composite, composite materials, Formula Student, formula-sae, fsae, FSAE Car, meshing, Monocoque, roll-cage, Student Team
June 6, 2022 at 9:30 am
Watch & Learn
ParticipantIn this video, you will learn how to add composite materials for analysis through engineering data in ANSYS Workbench and how to create suitable meshing and name selections for the ply layup. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
