Tagged: 19.2, FLUENT Meshing/Tgrid, fluid-dynamics, General, meshing
May 15, 2023 at 8:33 amSolutionParticipant
Marking multi faces is restricted by max edge count control. Please increase max edge count from 10 to say 1000. Then mark multi faces. This should show you multi faces. Please see attached video for the same.
1. 2056474.mp4
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
