Tagged: 3d, 3D design, Ansys Discovery, constraints, Copy, Explore, General (2D), History Tracking, Model, parameters, Record, Refine Stage, retain, save, sketch, Sketch Constraint
January 10, 2024 at 11:56 am
SolutionParticipantIn Ansys Discovery, retaining a sketch is an important step in the design process. When you are working with constraints in your sketch, it’s important to remember that these constraints are active only in 2D sketch mode. If you switch to 3D mode, the existing constraint data is deleted.
Please refer the attached document for ways to manage and retain sketches in Ansys Discovery.
- Surface to solid creation in SpaceClaim
- Split Face in SpaceClaim
- FAQ – Share Topology is now available in Discovery 2021 R2
- Selecting all inner faces of a body
- Ansys Discovery – Working with Components
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Ansys Discovery for Geometry Preparation
- Quick Tips for Volume extraction in SpaceClaim
- Ansys Discovery – Detect Tool
