Log Messages are not displayed in the terminal even though -monitor flag is used for LSF job submission
Tagged: 18.2, HFSS - SYS, Installation/Licensing/Systems, Remote Solve, rsm
May 15, 2023 at 8:33 am
SolutionParticipantWhen a job is submitted to LSF, usually its output is not displayed on the terminal. Instead you need to use the following LSF command: bpeek to see the same output. You can use this command for any AnsysEM job on a LSF cluster that is currently running. If you have multiple jobs running, you need to specify its job ID. After the job is over, the user can review the batch log file. See the attached pdf for more detailed instructions on how to use the bpeek command.
1. Log_Messages_Not_Displayed_using_-monitor_for_LSF_Submission.pdf
