June 5, 2023 at 7:05 am
FAQ
ParticipantMicrosoft Direct Access is built on IPv6 Currently, the ANSYS License Manager supports IPv4 and does not support IPv6. We recommend that you either turn off IPv6 or make IPv4 the default; otherwise, the clients will fail to connect to the license server (network error). We are currently researching supporting IPv6.
